cerco info "elpro"
  • cerco info "elpro"
    chi conosce la "elpro" ??
    ho un ampli fm mod 4500 e non so' nulla..
    fabio
    Re: cerco info "elpro"
    BROADCAST FM AMPLIFIER
    Range frequency: 87.5 - 108 MHz
    INNOVACTION Mod. ROCK 1K3
    Power output: 1300 Watt RF................................................ .......
    Specifications:
    Power supply: 230 V.a.c. 50 Hz
    Power input: 20 Watt RF
    Power output: (adjustable) 200 at 1300 Watt RF
    Protection on every part
    Technical characteristics
    RF Input connector: "N" Female
    RF Output connector: "7/16" Female
    Front out connector (BNC) for the
    RF measurements (TEST -40 dB
    Output connector for external power supply exciter
    (230 V.a.c.) with voltage drop in case of intervention
    protection (prevents damage to the transmitter)
    Connector for control "REMOTE" outside
    Protection: SWR (standing wave)
    Absorption in excessive current
    High temperature
    Excess pilot input, etc ...
    Button on front panel for any "RESET"
    of protection (in case of intervention)
    Forced-air cooling.
    RF filter for attenuation
    of frequencies
    harmonics integrated.
    Buttons on front panel for setting
    readings on the display.
    LCD backlit panel for the
    visualization of the functions:
    Reading of the RF output power direct, reflected,
    current consumption in operation (Amperes),
    supply voltage to the RF power MOSFET,
    internal temperature etc ...
    pescar-inter 0-2 snejder-milito pe mo
      in itagliano puro
      :::::::::::: ::::::::::::::::::::::::::::::::::::::::::::: Caratteristiche tecniche Connettore di ingresso RF : "N" femmina RF Connettore in uscita: "7/16" femmina frontale out (BNC) per le misure RF TEST (-40 dB Connettore di uscita per eccitatore alimentazione esterna (230 Vac) con caduta di tensione in caso di intervento di protezione ( previene i danni al trasmettitore) Connettore per il controllo "REMOTE" al di fuori di protezione: SWR (onda stazionaria) Assorbimento in corrente eccessiva per alte temperature intervento del pilota in eccesso, ecc ... pulsante sul pannello frontale per un "RESET" di protezione (in caso di intervento ) . Raffreddamento ad aria forzata RF filtro per l'attenuazione delle frequenze . armoniche integrati tasti sul pannello frontale per impostare le letture sul display. pannello LCD retroilluminato per la visualizzazione delle funzioni: Lettura della potenza RF diretta, riflessa, il consumo di corrente in funzione (Ampere), la tensione di alimentazione del MOSFET di potenza RF, ecc temperatura interna ... pescar-Inter 0-2 Snejder-Milito pe mo
        ma dove hai copiato??????
        monta la 1500 ?
        notare i 2 trasformatori molto sovradimensionati nonostante sia a 220.
        sopratutto il "piccolo" se e' per il filamento e' veramente enorme..
        fabio
          vedi se trovi qualcosa qui
          http://radiotimefirenze.altervista.o...e_tecnico.html
          dalle indicazioni che hai dato risulta essere questo come marca e modello
          http://www.ebay.it/itm/BROADCAST-FM-...t_11229wt_1399
            ho visto il trafo per il filamento, e' posizionato sotto il vano valvola,
            il grande e' per l'anodica, mancano info per quello a sx in foto..
            allego 2 foto di un onesto rake fm, sempre valvola 1500
            ma una differenza abissale nell'alimentatore
            tony, quello che hai trovato non c'entra, il mio 4500 e' una macchina anni 80.
            fabio
Nome:   CIMG4285.jpg
Dimensione: 337.0 KB
            Ultima modifica di i4fyf; 27-08-12, 13:49.
              eccoli....
