(in italiano più giù)
[click on the picture to full view]
Let's see the situation with the solar cycle # 24.
All data needed for the following charts comes from the Space Weather Canada, SIDC and WSO.
Unless otherwise indicated, I refer the "adjusted" values of the solar flux, corrected (by Space Weather Canada) to refer to the average Earth-Sun distance (1 Astronomical Unit).
This is the graph of the solar flux on 2800MHz from the month of the previous minimum smoothed solar flux (October 2008) to the present. The blue curve is the monthly mean value of solar flux, while the red one is the smoothed value.
The values of the solar flux in the past three months, along with those of the previous 10 months, bringing the smoothed value of February, March and April 2014, respectively to 139, 141 and 144 s.f.u.
The curve of the smoothed values, therefore, continues to rise, indicating a second peak of solar activity much higher than the first one (127 sfu in March 2012) .The highest monthly mean of solar flux was 166 s.f.u. in February 2014. The previous peak was 150 s.f.u. in November 2011.
The next chart is the comparison chart, in terms of Smoothed Sunspot Number, between the solar cycle #24 and all the previous ones.
This chart starts from the month of the previous minimun smoothed sunspot number (december 2008).
The curve of the solar cycle #24 is the red one.
If we consider this curve, we can observe that, in April 2014, ie 64 months after the start of the solar cycle (December 2008), the Smoothed Sunspot Number of Solar Cycle #24 was higher than that of solar cycles #1, #3 , #5, #6, #7, #10, #12, #13, #14, #15 and #16! Who would have thought?
This, finally, is the comparison chart between the SSN curves of solar cycles #23 and #24. In April 2014, the SSN value of the solar cycle in progress is about 40% lower than the previous cycle.
The next update in early february 2015.
[italiano]
Vediamo la situazione del ciclo solare #24.
Tutti i dati necessari per l'elaborazione dei grafici seguenti, da me personalmente eseguita con Excel, sono stati ricavati da Space Weather Canada e dal SIDC. Faccio, inoltre, riferimento, in questi grafici, se non diversamente indicato, ai valori "adjusted" del flusso solare, ossia corretti (dallo Space Weather Canada) per riferirli alla distanza media Terra-Sole (1 Unità Astronomica).
Questo è il grafico relativo all'andamento del flusso solare sui 2800MHz dal mese del minimo del flusso solare smoothed (ottobre 2008) fino all'attualità. La curva blu è quella del valore medio mensile del flusso solare, mentre quella rossa è quella del valore smoothed.
I valori del flusso solare nei tre mesi scorsi , insieme a quelli dei 10 mesi precedenti, portano il valore smoothed di febbraio, marzo e aprile 2014 rispettivamente a 139, 141 e 144 s.f.u. La curva dei valori smoothed, quindi, continua a salire indicando un secondo picco di attività solare decisamente più alto del primo (127 s.f.u. a marzo 2012).Il valore medio mensile più alto del flusso solare è stato pari a 166 s.f.u. nel mese di febbraio 2014. Il precedente picco del valore medio mensile era stato di 150 s.f.u. nel mese di novembre 2011.
Il prossimo grafico è il grafico di confronto tra la risalita, in termini di Smoothed Sunspot Number, del ciclo solare #24 e quella dei cicli precedenti.
Questo grafico parte dal mese del precedente minimo dello Smoothed Sunspot Number (dicembre 2008). La curva del ciclo solare 24 è quella rossa.
Se consideriamo questa curva, possiamo osservare che, nel mese di aprile 2014 , cioè 64 mesi dopo l'inizio del ciclo solare (dicembre 2008), il valore Smoothed Sunspot Number del ciclo solare #24 era superiore a quello dei cicli solari 1, 3, 5, 6, 7, 10, 12, 13, 14, 15 e 16 ! Chi l'avrebbe detto ?
Questo, invece , è il grafico comparativo tra le curve SSN dei cicli solari 23 e 24. Ad aprile 2014 il valore SSN del ciclo solare in corso è inferiore del 40 % circa a quello del ciclo solare precedente.
Il prossimo aggiornamento ai primi di febbraio 2015.
[italiano]
