(in italiano più giù)
[click on the picture to full view]
Let's see the situation with the solar cycle # 24.
All data needed for the following charts comes from the Space Weather Canada, SIDC and WSO.
Unless otherwise indicated, I refer the "adjusted" values of the solar flux, corrected (by Space Weather Canada) to refer to the average Earth-Sun distance (1 Astronomical Unit).
This is the graph of the solar flux on 2800MHz from the month of the previous minimum smoothed solar flux (October 2008) to the present. The blue curve is the monthly mean value of solar flux, while the red one is the smoothed value.
It seems that the long-term trend is to decrease, although there are fluctuations up. If, however, this solar cycle should be similar to #14, we would witness for quite some time now swings, up and down, up to a more decisive and definitive start toward the minimum.
Look at this graph. It is the comparison between the current solar cycle and the cycle # 14.
We will see in the coming months as the situation evolves
The next chart is the comparison chart, in terms of Smoothed Sunspot Number, between the solar cycle #24 and all the previous ones.
This chart starts from the month of the previous minimun smoothed sunspot number (december 2008).
The curve of the solar cycle #24 is the red one.
The smoothed sunspot number is sill around 60.
As known, in correspondence of the maximum of solar cycle there is an inversion of the magnetic poles of the Sun. Through the measures of the Wilcox Solar Observatory, we can see how this inversion evolves.
As you can see, the average curve (yellow) has reached zero (exactly between May and June). However, the southern hemisphere has not yet reversed magnetic polarity.
The next update in early November 2013.
[italiano]
Vediamo la situazione del ciclo solare #24.
Tutti i dati necessari per l'elaborazione dei grafici seguenti, da me personalmente eseguita con Excel, sono stati ricavati da Space Weather Canada e dal SIDC. Faccio, inoltre, riferimento, in questi grafici, se non diversamente indicato, ai valori "adjusted" del flusso solare, ossia corretti (dallo Space Weather Canada) per riferirli alla distanza media Terra-Sole (1 Unità Astronomica).
Questo è il grafico relativo all'andamento del flusso solare sui 2800MHz dal mese del minimo del flusso solare smoothed (ottobre 2008) fino all'attualità. La curva blu è quella del valore medio mensile del flusso solare, mentre quella rossa è quella del valore smoothed.
Sembra che la tendenza a lungo termine sia ormai quella alla diminuzione, nonostante ci siano oscillazioni in su'. Se, tuttavia, questo ciclo solare dovesse essere simile al #14, assisteremmo per un bel pò di tempo a queste oscillazioni, su e giù, fino ad un più decisivo e definitivo avvio verso il nuovo minimo.
Guardiamo questo grafico. Esso è il confronto tra il ciclo solare attuale e il numero 14.
Vedremo nei prossimi mesi come evolverà la situazione.
Il prossimo grafico è il grafico di confronto tra la risalita, in termini di Smoothed Sunspot Number, del ciclo solare #24 e quella dei cicli precedenti.
Questo grafico parte dal mese del precedente minimo dello Smoothed Sunspot Number (dicembre 2008). La curva del ciclo solare 24 è quella rossa.
La curva dello Smoothed Sunspot Number si mantiene poco più giù dei 60.
Come è noto, in corrispondenza del massimo del ciclo solare si verifica l'inversione dei poli magnetici del Sole. Attraverso le misure del Wilcox Solar Observatory, possiamo vedere come si evolve l'inversione.
Come possiamo vedere, la curva dei valori medi (gialla) ha raggiunto il valore zero passando poi dall'altra parte (esattamente tra maggio e giugno). Tuttavia, l'emisfero sud non ha ancora invertito la propria polarità magnetica.
Il prossimo aggiornamento ai primi di novembre 2013.
[italiano]
