(in italiano più giù)
[click on the picture to full view]
Let's see the situation with the solar cycle # 24.
All data needed for the following charts comes from the Space Weather Canada, SIDC and WSO.
Unless otherwise indicated, I refer the "adjusted" values of the solar flux, corrected (by Space Weather Canada) to refer to the average Earth-Sun distance (1 Astronomical Unit).
This is the graph of the solar flux on 2800MHz from the month of the previous minimum smoothed solar flux (October 2008) to the present. The blue curve is the monthly mean value of solar flux, while the red one is the smoothed value.
After a declining trend from april to september 2012, the smoothed solar flux has increased slightly in October 2012, thanks to the monthly mean value of April 2013 (abt 124 sfu).
This is the comparison chart, in terms of Smoothed Sunspot Number, between the solar cycle #24 and all the previous ones. This chart starts from the month of the previous minimun smoothed sunspot number (december 2008).
The curve of the solar cycle #24 is the red one.
The smoothed sunspot number is stable around 58 from June 2012, after a declining trend from march to july 2012.
As known, in correspondence of the maximum of solar cycle there is an inversion of the magnetic poles of the Sun. Through the measures of the Wilcox Solar Observatory, we can see how this inversion evolves.
As you can see, the average curve (yellow) has almost reached zero (exactly -3 in date 07-01-2013). Then the value has once again moved away from zero (-5 in January and February 2013 and -4 in March and April).
Also, the curves of the monthly mean values for the northern hemisphere and the southern one have in recent months a trend a little uneven.
Let's see in the next months.
The next update in early August 2013.
[italiano]
Vediamo la situazione del ciclo solare #24.
Tutti i dati necessari per l'elaborazione dei grafici seguenti, da me personalmente eseguita con Excel, sono stati ricavati da Space Weather Canada e dal SIDC. Faccio, inoltre, riferimento, in questi grafici, se non diversamente indicato, ai valori "adjusted" del flusso solare, ossia corretti (dallo Space Weather Canada) per riferirli alla distanza media Terra-Sole (1 Unità Astronomica).
Questo è il grafico relativo all'andamento del flusso solare sui 2800MHz dal mese del minimo del flusso solare smoothed (ottobre 2008) fino all'attualità. La curva blu è quella del valore medio mensile del flusso solare, mentre quella rossa è quella del valore smoothed. Dopo una fase calante da aprile a settembre 2012, la curva del flussolare sui 2800MHz è risalita in ottobre 2012, grazie al valore medio mensile di aprile 2013 (circa 124 sfu).
Questo è il grafico di confronto tra la risalita, in termini di Smoothed Sunspot Number, del ciclo solare #24 e quella dei cicli precedenti. Questo grafico parte dal mese del precedente minimo dello Smoothed Sunspot Number (dicembre 2008). La curva del ciclo solare 24 è quella rossa.
La curva dello Smoothed Sunspot Number è stabile intorno ad un valore di 58, da giugno 2012, dopo una fase calante da marzo a luglio 2102.
Come è noto, in corrispondenza del massimo del ciclo solare si verifica l'inversione dei poli magnetici del Sole. Attraverso le misure del Wilcox Solar Observatory, possiamo vedere come si evolve l'inversione.
Come potete vedere, la curva dei valori medi (gialla) ha quasi raggiunto lo zero (esattamente il valore -3 in data 07-01-2013). Successivamente il valore si è nuovamente mosso verso il basso (-5 in gennaio e febbraio 2013 e -4 in marzo e aprile). Inoltre, le curve dei valori medi mensili per l'emisfero nord e per quello sud del Sole mostrano negli ultimi mesi un andamento un pò irregolare.
Vediamo nei prossimi mesi
Il prossimo aggiornamento ai primi di agosto 2013.
[italiano]
