[click on the picture to full view]
Let's see the situation with the solar cycle # 24.
All data needed for the following charts comes from the Space Weather Canada and SIDC.
Unless otherwise indicated, I refer the "adjusted" values of the solar flux, corrected (by Space Weather Canada) to refer to the average Earth-Sun distance (1 Astronomical Unit).
This is the graph of the solar flux on 2800MHz from the month of the previous minimum smoothed solar flux (October 2008) to the present. The blue curve is the monthly mean value of solar flux, while the red one is the smoothed value.
As you can see, it seems that the solar cycle is now in decline overt. From april to july 2012, the solar flux smoothed has been declining and currently there are no signs of recovery.
This is the comparison chart, in terms of Smoothed Sunspot Number, between the solar cycle #24 and all the previous ones. This chart starts from the month of the previous minimun smoothed sunspot number (december 2008).
The curve of the solar cycle #24 is the red one.
Also the smoothed sunspot number has been falling from march to july 2012.
As known, in correspondence of the maximum of solar cycle there is an inversion of the magnetic poles of the Sun. Through the measures of the Wilcox Solar Observatory, we can see how this inversion evolves.
As you can see, the average curve (yellow) has almost reached zero (exactly -3 in date 07-01-2013). So we are very close to the reversal.
Let's see in the next months.
The next update in early may 2013.
[fare click sulle immagini per ingrandirle]
Vediamo la situazione del ciclo solare #24.
Tutti i dati necessari per l'elaborazione dei grafici seguenti, da me personalmente eseguita con Excel, sono stati ricavati da Space Weather Canada e dal SIDC. Faccio, inoltre, riferimento, in questi grafici, se non diversamente indicato, ai valori "adjusted" del flusso solare, ossia corretti (dallo Space Weather Canada) per riferirli alla distanza media Terra-Sole (1 Unità Astronomica).
Questo è il grafico relativo all'andamento del flusso solare sui 2800MHz dal mese del minimo del flusso solare smoothed (ottobre 2008) fino all'attualità. La curva blu è quella del valore medio mensile del flusso solare, mentre quella rossa è quella del valore smoothed. Come si può vedere, sembra che il ciclo solare sia ormai in fase calante conclamata. Dal mese di aprile a quello di luglio 2012, infatti, il valore smoothed del flusso solare è andato sempre diminuendo e non ci sono al momento segni di ripresa.
Questo è il grafico di confronto tra la risalita, in termini di Smoothed Sunspot Number) del ciclo solare #24 e quella dei cicli precedenti. Questo grafico parte dal mese del precedente minimo dello Smoothed Sunspot Number (dicembre 2008). La curva del ciclo solare 24 è quella rossa.
Anche il valore smoothed del numero di macchie solari è andato diminuendo da marzo a luglio 2012.
Come è noto, in corrispondenza del massimo del ciclo solare si verifica l'inversione dei poli magnetici del Sole. Attraverso le misure del Wilcox Solar Observatory, possiamo vedere come si evolve l'inversione.
Come si può vedere, la curva gialla del valore medio ha quasi raggiunto lo zero (esattamente -3 il 7-01-2013) , siamo quindi molto vicini all'inversione.
Vediamo cosa succede nei prossimi mesi.
Il prossimo aggiornamento ai primi di maggio 2013.
