Solar cycle 24 - summary of last quarter August to October 2012
  • Solar cycle 24 - summary of last quarter August to October 2012
    [click on the picture to full view]
    As usual, take stock of the situation with the solar cycle # 24.
    All data needed for the following charts comes from the Space Weather Canada and SIDC.
    Unless otherwise indicated, I refer the "adjusted" values of the solar flux, corrected (by Space Weather Canada) to refer to the average Earth-Sun distance (1 Astronomical Unit).
Nome:   flusso adj novembre 2012.jpg
Dimensione: 170.8 KB
    This is the graph of the solar flux on 2800MHz from the month of the previous minimum smoothed solar flux (October 2008) to the present. The red curve is the monthly mean value of solar flux, while the blue one is the smoothed value.
    As indicated by the white arrow, in the month of April 2012 there was a decrease in the smoothed solar flux if compared to the previous month. Is the first time that this happens after the minimum of smoothed solar flux in october 2008.
Nome:   risalita cicli 1749_2012_novembre2012.jpg
Dimensione: 386.2 KB
    This is the comparison chart, in terms of Smoothed Sunspot Number, between the solar cycle #24 and all the previous ones. This chart starts from the month of the previous minimun smoothed sunspot number (december 2008).
    The curve of the solar cycle #24 is with the red squares.
    As before, the white arrow indicates that in the month of March 2012 there was a decrease in the smoothed sunspot number compared to the previous month. Also in April, there was a decrease.
    Furthermore, I updated the graph where you can see better the rising of the cycles #24 and the previous one #23.
Nome:   confronto cicli 23 e 24 _ novembre 2012.jpg
Dimensione: 183.7 KB
    The difference between the two cycles is increasingly evident.
    What to say about the first decrease in the smoothed solar flux (Aprile 2012) and the smoothed sunspot number (March and April 2012) ?
    In the recent past solar cycles there were two peaks of solar activity, and not just one. It's likely that even the solar cycle #24 will be the same.
    As is known, in correspondence of the maximum of a solar cycle there is an inversion of the magnetic poles of the Sun. Through the measures of the Wilcox Solar Observatory, we can see how this inversion evolves.
Nome:   polar field novembre 2012.jpg
Dimensione: 439.8 KB
    As you can see, the south pole (red thick curve) has not yet reached the inversion, while the north pole.
    Let's see in the next months.
    The next update in early February 2013.
    [fare click sulle immagini per ingrandirle]
    Come di consueto, facciamo il punto della situazione del ciclo solare #24.
    Tutti i dati necessari per l'elaborazione dei grafici seguenti, da me personalmente eseguita con Excel, sono stati ricavati da Space Weather Canada e dal SIDC. Faccio, inoltre, riferimento, in questi grafici, se non diversamente indicato, ai valori "adjusted" del flusso solare, ossia corretti (dallo Space Weather Canada) per riferirli alla distanza media Terra-Sole (1 Unità Astronomica).
    Questo è il grafico relativo all'andamento del flusso solare sui 2800MHz dal mese del minimo del flusso solare smoothed (ottobre 2008) fino all'attualità. La curva rossa è quella del valore medio mensile del flusso solare, mentre quella blu è quella del valore smoothed.
    Come indicato dalla freccia bianca, nel mese di aprile 2012 si è registrata una diminuzione del valore rispetto a quello del mese precedente. Questa è la prima volta che ciò accade dopo il minimo del flusso solare smoothed (ottobre 2008).
    Questo è il grafico di confronto tra la risalita, in termini di Smoothed Sunspot Number) del ciclo solare #24 e quella dei cicli precedenti. Questo grafico parte dal mese del precedente minimo dello Smoothed Sunspot Number (dicembre 2008). La curva del ciclo solare 24 è quella con i quadratini rossi.
    Come prima, la freccia bianca indica che nel mese di marzo 2012 si è verificata una diminuzione del valore rispetto al mese precedente. Una diminuzione si è avuta anche nel mese di aprile 2012.
    Ho, inoltre, aggiornato l'altro grafico dove si vedono meglio le risalite dei cicli solari #24 e #23.
    La differenza tra i due cicli è sempre più evidente.
    Che dire circa la prima diminuzione del flusso solare smoothed (Aprile 2012) e il numero di macchie solari smoothed (marzo e aprile 2012)?
    Negli ultimi cicli solari ci sono stati due picchi di attività solare, e non uno solo. E' probabile che anche il ciclo solare # 24 sarà lo stesso.
    Come è noto, in corrispondenza del massimo del ciclo solare si verifica l'inversione dei poli magnetici del Sole. Attraverso le misure del Wilcox Solar Observatory, possiamo vedere come si evolves l'inversione.
    Come si può vedere, il polo sud (curva rossa spessa) non ha ancora raggiunto l'inversione, mentre il polo nord si.
    Vediamo nei prossimi mesi.
    Il prossimo aggiornamento ai primi di febbraio 2013.
