Solar cycle 24 - summary of last quarter February to April 2012
  • Solar cycle 24 - summary of last quarter February to April 2012
    (in italiano più giù)
    I summarize what happened in the last quarter to solar activity.
    All data needed for the following charts are from the Space Weather Canada. You will therefore notice that I speak only in terms of solar flux at 2800 MHz. I chose to take only this parameter for the study of solar activity because certainly more reliable and objective than the sunspot number. To note, however, that there is a correlation between solar flux and 2800MHz on the number of sunspots.
    I refer, in such plots, unless otherwise indicated, the values "adjusted" of the solar flux, corrected (by the Space Weather Canada) to refer to the average Earth-Sun distance (1 astronomical unit), since the actual Earth-Sun distance increases and decreases in summer and winter.
    These are the charts of the last three months.
    February 2012
Nome:   flusso adj febbraio 2012.jpg
Dimensione: 159.7 KB
    March 2012
Nome:   flusso adj marzo 2012.jpg
Dimensione: 173.2 KB
    April 2012
Nome:   flusso adj aprile 2012.jpg
Dimensione: 159.8 KB
    The next one is the graph of the solar flux on 2800MHz from the month of the minimum smoothed solar flux (October 2008) to the present. The red curve is the average monthly value of solar flux, while the blue one is the smoothed value. The data considered are the flux "Adjusted", derived from those physically measured by the Observatory of Penticton (Canada).
Nome:   risalita ciclo 24 _ maggio 2012.jpg
Dimensione: 201.5 KB
    Considerations.
    In the month of february, the Sun has been quiet , with solar activity at low level in terms of sunspot number and solar flux on 2800 MHz. In march and april, the solar activity har risen. in particular, in the month of April we found increased activity in the southern hemisphere of the sun with many active region and sunspots. Anyway, you can still see the effects on the graph of the decline of solar activity observed from December to February. At the moment there is no sign of an imminent new and strong rising solar activity. If this happens, the smoothed curve will rise. I remember the max of this solar cycle is planned for 2013.
    Now the graph (in terms of Smoothed Sunspot Number) comparing the rising of the solar cycle #24 and that of previous solar cycles:
Nome:   risalita cicli 1749_2012_maggio2012.jpg
Dimensione: 476.7 KB
    The curve of the solar cycle #24 is the one with the red squares.
    Until now the solar cycle #24 has reached or exceeded, in terms of SSN, the solar cycles #1, #5, #6, #7, #12, #14 and it seems to be approaching the solar cycles #9 and #16.
    The current solar cycle and the previous one ? I updated the graph where you can see the rising of the two cycles, the#23 and the #24.
Nome:   confronto cicli 23 e 24 _ maggio 2012.jpg
Dimensione: 234.8 KB
    The solar cycle #24 remains below the previous one, as evidenced by the smoothed curves.
    The next update in early august 2012.
    [fare click sulle immagini per ingrandirle]
    Come di consueto, riassumo quanto si è potuto constatare nell'ultimo trimestre a livello di attività solare.
    Tutti i dati necessari per l'elaborazione dei grafici seguenti, da me personalmente eseguita con Excel, sono stati ricavati da Space Weather Canada. Noterete, quindi, che si parlerà in essi esclusivamente di flusso solare sui 2800 MHz. Ho scelto di adottare solo questo parametro per lo studio dell'attività solare perchè sicuramente più attendibile e obiettivo rispetto al numero di macchie solari. Per il significato e modalità di misura del Solar Flux @2800MHz rinvio all'articoletto n.2 in formato acrobat a suo tempo pubblicato su questo forum. Da tenere presente, in ogni caso, che esiste una correlazione tra flusso solare sui 2800MHz e numero di macchie solari, di cui parlo brevemente sempre nell'articoletto acrobat sopra richiamato. Faccio, inoltre, riferimento, in questi grafici, se non diversamente indicato, ai valori "adjusted" del flusso solare, ossia corretti (sempre dallo Space Weather Canada) per riferirli alla distanza media Terra-Sole (1 Unità Astronomica), considerato che la distanza effettiva Terra-Sole aumenta in estate e diminuisce in inverno. Anche questo particolare aspetto viene brevemente spiegato nell'articoletto acrobat sopra richiamato.
    Questi sono i grafici degli ultimi tre mesi.
    February 2012
    March 2012
    April 2012
    Riporto ora il grafico relativo all'andamento del flusso solare sui 2800MHz dal mese del minimo del flusso solare smoothed (ottobre 2008) fino all'attualità. La curva rossa è quella del valore medio mensile del flusso solare, mentre quella blu è quella del valore smoothed. Circa la modalità di calcolo del valore smoothed rinvio al solito articoletto n.2 in formato acrobat.
    Dati considerati, quelli del flusso "adjusted", derivati da quelli fisicamente misurati dall'osservatorio di Penticton (Canada).
    Considerazioni
    Nel mese di febbraio, il Sole è risultato tranquillo, con l'attività solare a bassi livelli in termini di numero di macchie solari e flusso solare sui 2800 MHz. In marzo e aprile, l'attività solare ha ripreso a salire. in particolare, nel mese di aprile abbiamo constatato una maggiore attività nell'emisfero meridionale del sole con molte regioni attive con macchie solari. In ogni caso, è ancora possibile vedere gli effetti sul grafico del declino dell'attività solare osservata da dicembre a febbraio. Al momento non vi è segno di un imminente nuovo e forte aumento dell'attività solare. Se questa dovesse verificarsi la curva smoothed tornerà a salire. Ricordo che il massimo di questo ciclo solare è previsto per il 2013.
    Ho aggiornato il grafico comparativo tra la risalita in termini di SSN del ciclo solare 24 e quella dei cicli precedenti
    La curva del ciclo solare 24 è quella con i quadratini rossi
    Fino ad ora il ciclo solare # 24 ha raggiunto o superato, in termini di SSN, i cicli solari # 1, # 5, # 6, # 7, # 12, # 14 e sembra avvicinarsi ai cicli solari #9 e # 16.
    Cosa possiamo dire circa l'attuale ciclo solare e quello precedente ? Ho aggiornato anche l'altro grafico dove si vedono le risalite di questi due cicli solari:
    Il ciclo solare #24 resta al disotto di quello precedente, come attestato dalla curva smoothed.
    Il prossimo aggiornamento ai primi di agosto 2012.
