(italiano più giù)
look below for the final contest-plan resulting from this work
click here
The ARRL Contest-10m is approaching. It would be a shame not to participate right now that 10m are finally open via F2 layer.
I think it is good to strike while the iron is hot ..
Like I do almost every time I participate to a contest in single band singole operator category, I began to realize a sort of contest-plan related to the likely openings in the 10m to the various areas of the globe.
In addition to the aid of the usual VOACAP-based software (WinCAP in particular), I thought this time to establish the realization of the contest-plan on the actual conditions encountered in radio from here to the eve of the contest, so then they can be compared with those estimated with software and derive from this comparison a contest-plan closer to reality.
How am I taking into account the conditions really encountered in radio ?
I'm using the CW-skimmer by VE3NEA combined with GPcluster by IH9GPI.
This software contains a very interesting resource.
In particular, it allows to export in Excel format the sequence of spots received from the dxcluster. In my case, I set as the node only the local CW-Skimmer. Thus, the spots on which the next job will then be made with Excel, are those of the stations actually heard from my receiver (Perseus with CW-Skimmer with omni-directional antenna).
The above work of listening, reporting and filing stations will run automatically on a daily basis, for all 24 hours of the day.
On the basis of the excel file each day, then proceed to make the necessary statistics, obtaining in practice, the hourly number of stations received from Asia, Europe, South America etc.. thereby resulting in the opening and closing graphs to the respective areas. These graphs are then compared with those resulting from the VOACAP-based software and you'll get the final contest-plan.
click here
__________________________________________________ _______________________
Il contest ARRL-10m è ormai prossimo. Sarebbe un vero peccato non parteciparvi proprio ora che i 10m sono finalmente aperti via strato F2.
Penso che è bene battere il ferro finchè è caldo..
Come faccio quasi sempre quando prevedo di partecipare ad un contest come singolo operatore singola banda, ho cominciato pure stavolta a realizzare una sorta di contest-plan relativo alle probabili aperture in 10m verso le varie aree del Globo.
Oltre all'ausilio dei soliti software VOACAP-based (WinCAP in primis) , ho pensato questa volta di fondare la realizzazione del contest-plan anche sulle effettive condizioni riscontrabili in radio da qui alla vigilia del contest, così poi da poterle confrontare con quelle stimate con i software e ricavare da tale confronto un contest-plan più vicino alla realtà.
In che modo sto tenendo conto delle condizioni riscontrabili in radio ?
Sto utilizzando il CW-skimmer di VE3NEA abbinato al GPcluster di Giacomo IH9GPI.
Quest'ultimo software contiene delle risorse davvero interessanti.
In particolare, consente di esportare in formato Excel la sequenza di spots ricevuti da uno dei dx-cluster preimpostati. Nel mio caso, ho impostato come nodo da cui ricevere gli spots solo il CW-skimmer locale. In tal modo, gli spots su cui verrà poi fatto il lavoro successivo con Excel, sono quelli relativi a stazioni realmente ascoltate dal mio ricevitore (Perseus con CW-skimmer con antenna omnidirezionale).
Il suddetto lavoro di ascolto e segnalazione/archiviazione automatica delle stazioni ascoltate verrà eseguito giornalmente, per tutte le 24 ore del giorno.
Sulla scorta del file excel di ciascun giorno procederò poi a fare le opportune statistiche, ricavando in pratica il numero orario di stazioni ricevute da Asia, Europa, Sud America etc. ottenendo in tal modo dei grafici di apertura e chiusura verso le rispettive zone. Questi grafici verranno poi confrontati con quelli risultanti dall'uso dei software e se ne ricaverà così il contest-plan definitivo.
Mi farebbe piacere leggere il vostro parere in merito, come pure eventuali suggerimenti.
click here
click here
