(traduzione in italiano più giù)
[click on the picture to enlarge]
I summarize what happened in the last quarter to solar activity.
This time, we had a very interesting quarter.
All data necessary for the preparation of the following charts , I have personally done with Excel, have been built from Space Weather Canada. You will therefore notice that I speak only of solar flux at 2800 MHz. I chose to take only this parameter for the study of solar activity because certainly more reliable and objective than the sunspot number. To note, however, that there is a correlation between solar flux and 2800MHz on the number of sunspots.
I refer, in such plots, unless otherwise indicated, the values "adjusted" of the solar flux, correct (by the Space Weather Canada) to refer to the average Earth-Sun distance (1 astronomical unit), since the actual Earth-Sun distance increases and decreases in summer and winter.
These are the charts of the last three months.
August 2011
September 2011
October 2011
The next one is the graph of the solar flux on 2800MHz from the month of the minimum smoothed solar flux (October 2008) to the present. The red curve is the average monthly value of solar flux, while the blue one is the smoothed value. The data considered are the flux "Adjusted", derived from those physically measured by the Observatory of Penticton (Canada).
Considerations.
In the last three months we saw a strong rise in solar activity.
We saw a lot of active regions on the Sun, mainly in the northern hemisphere but also the southern hemisphere has begun to make a decisive contribution.
The solar flux was maintained at values more than 100 sfu, except for a brief period in August. The monthly mean values obtained were equal to 104, 136.7 and 136.5 respectively.
As a result of this acceleration, I updated the graph (in terms of Smoothed Sunspot Number) comparing the rising of the solar cycle #24 and that of previous solar cycles:
The curve of the solar cycle #24 is the one with the red squares.
What we can say about the current solar cycle and the previous one ? I made another graph where you can see the rising of the two cycles, the#23 and the #24.
From time to time the monthly mean values of Sunspot Number of the current solar cycle are close to those of Cycle #23, but on average the solar cycle #24 remains below the previous one, as evidenced by the smoothed curves.
The next update in early January 2012.
[fare click sulle immagini per ingrandirle]
Come di consueto, riassumo quanto si è potuto constatare nell'ultimo trimestre a livello di attività solare. Stavolta abbiamo avuto un trimestre molto interessante.
Tutti i dati necessari per l'elaborazione dei grafici seguenti, da me personalmente eseguita con Excel, sono stati ricavati da Space Weather Canada. Noterete, quindi, che si parlerà in essi esclusivamente di flusso solare sui 2800 MHz. Ho scelto di adottare solo questo parametro per lo studio dell'attività solare perchè sicuramente più attendibile e obiettivo rispetto al numero di macchie solari. Per il significato e modalità di misura del Solar Flux @2800MHz rinvio all'articoletto n.2 in formato acrobat a suo tempo pubblicato su questo forum. Da tenere presente, in ogni caso, che esiste una correlazione tra flusso solare sui 2800MHz e numero di macchie solari, di cui parlo brevemente sempre nell'articoletto acrobat sopra richiamato. Faccio, inoltre, riferimento, in questi grafici, se non diversamente indicato, ai valori "adjusted" del flusso solare, ossia corretti (sempre dallo Space Weather Canada) per riferirli alla distanza media Terra-Sole (1 Unità Astronomica), considerato che la distanza effettiva Terra-Sole aumenta in estate e diminuisce in inverno. Anche questo particolare aspetto viene brevemente spiegato nell'articoletto acrobat sopra richiamato.
Questi sono i grafici degli ultimi tre mesi.
Agosto 2011
Settembre 2011
Ottobre 2011
Riporto ora il grafico relativo all'andamento del flusso solare sui 2800MHz dal mese del minimo del flusso solare smoothed (ottobre 2008) fino all'attualità. La curva rossa è quella del valore medio mensile del flusso solare, mentre quella blu è quella del valore smoothed. Circa la modalità di calcolo del valore smoothed rinvio al solito articoletto n.2 in formato acrobat.
Dati considerati, quelli del flusso "adjusted", derivati da quelli fisicamente misurati dall'osservatorio di Penticton (Canada).
Considerazioni
Nei tre mesi trascorsi abbiamo potuto constatare una attività solare in decisa risalita.
Si sono viste molte regioni attive sul Sole, prevalentemente nell'emisfero nord ma anche l'emisfero sud ha cominciato a dare un deciso contributo.
Il flusso solare si è mantenuto su valori sempre superiore ai 100 s.f.u. , fatta eccezione per un breve periodo in agosto. I valori medi mensili raggiunti sono stati pari a 104, 136,7 e 136,5 rispettivamente.
A seguito di questa accelerazione, ho aggiornato il grafico comparativo tra la risalita in termini di SSN del ciclo solare 24 e quella dei cicli precedenti
La curva del ciclo solare 24 è quella con i quadratini rossi
Cosa possiamo dire circa l'attuale ciclo solare e quello precedente ? Ho fatto un altro grafico dove si vedono le risalite di questi due cicli solari:
Di tanto in tanto i valori medi mensili di Sunspot Number dell'attuale ciclo solare si avvicinano a quelli del ciclo 23, ma mediamente il ciclo solare 24 resta al disotto di quello precedente, come attestato dalla curva smoothed.
Il prossimo aggiornamento ai primi di gennaio 2012.
August 2011
September 2011
October 2011
Considerations.
Agosto 2011
Settembre 2011
Ottobre 2011
Considerazioni
