(traduzione in italiano più giù)
As usual, I summarize what happened in the last quarter to solar activity.
All data necessary for the preparation of the following charts , I have personally done with Excel, have been built from Space Weather Canada. You will therefore notice that I speak only of solar flux at 2800 MHz. I chose to take only this parameter for the study of solar activity because certainly more reliable and objective than the sunspot number. To note, however, that there is a correlation between solar flux and 2800MHz on the number of sunspots.
I refer, in such plots, unless otherwise indicated, the values "adjusted" of the solar flux, correct (by the Space Weather Canada) to refer to the average Earth-Sun distance (1 astronomical unit), since the actual Earth-Sun distance increases and decreases in summer and winter.
These are the charts of the last three months.
The next one is the graph of the solar flux on 2800MHz from the month of the minimum smoothed solar flux (October 2008) to the present. The red curve is the average monthly value of solar flux, while the blue one is the smoothed value. The data considered are the flux "Adjusted", derived from those physically measured by the Observatory of Penticton (Canada).
Considerations. Like a year ago, after the strong acceleration of March, there has been a new downsizing of the solar cycle rising, with the months characterized by solar activity averages around 100 sfu. The impression is that, like last year, has been passed a new "step" of the cycle rising. In practice, once again there was a peak of solar activity in March (last year was in February) after which the activity has stabilized at lower values of the peak but above the previous year. Overall, the solar cycle continues its rising, while remaining one of the weakest since the solar activity is measured in terms of sunspots (1749) or in terms of solar flux at 2800 MHz (1947). In this regard, I'm writing an article to be published shortly in the same section of the forum.
The next update in early November.
Come di consueto, riassumo quanto si è potuto constatare nell'ultimo trimestre a livello di attività solare.
Tutti i dati necessari per l'elaborazione dei grafici seguenti, da me personalmente eseguita con Excel, sono stati ricavati da Space Weather Canada. Noterete, quindi, che si parlerà in essi esclusivamente di flusso solare sui 2800 MHz. Ho scelto di adottare solo questo parametro per lo studio dell'attività solare perchè sicuramente più attendibile e obiettivo rispetto al numero di macchie solari. Per il significato e modalità di misura del Solar Flux @2800MHz rinvio all'articoletto n.2 in formato acrobat a suo tempo pubblicato su questo forum. Da tenere presente, in ogni caso, che esiste una correlazione tra flusso solare sui 2800MHz e numero di macchie solari, di cui parlo brevemente sempre nell'articoletto acrobat sopra richiamato. Faccio, inoltre, riferimento, in questi grafici, se non diversamente indicato, ai valori "adjusted" del flusso solare, ossia corretti (sempre dallo Space Weather Canada) per riferirli alla distanza media Terra-Sole (1 Unità Astronomica), considerato che la distanza effettiva Terra-Sole aumenta in estate e diminuisce in inverno. Anche questo particolare aspetto viene brevemente spiegato nell'articoletto acrobat sopra richiamato.
Questi sono i grafici degli ultimi tre mesi.
Riporto ora il grafico relativo all'andamento del flusso solare sui 2800MHz dal mese del minimo del flusso solare smoothed (ottobre 2008) fino all'attualità. La curva rossa è quella del valore medio mensile del flusso solare, mentre quella blu è quella del valore smoothed. Circa la modalità di calcolo del valore smoothed rinvio al solito articoletto n.2 in formato acrobat.
Dati considerati, quelli del flusso "adjusted", derivati da quelli fisicamente misurati dall'osservatorio di Penticton (Canada).
Considerazioni. Come un anno fa, dopo la forte accelerazione di marzo scorso, si è assistito ad un nuovo ridimensionamento della risalita del ciclo solare, con i mesi successivi caratterizzati da attività solare attestata mediamente intorno ai 100 sfu. L'impressione è che , come l'anno scorso, sia stato superato un nuovo "gradino" della risalita del ciclo. In pratica, anche stavolta si è verificato un picco di attività solare a marzo (l'anno scorso fu a febbraio) dopo il quale l'attività si è stabilizzata a valori più bassi del picco ma al disopra di quelli dell'anno precedente. Nel complesso, il ciclo solare continua la sua risalita, pur restando uno dei più deboli da quando si misura l'attività solare in termini di macchie solari (1749) o in termini di flusso solare sui 2800 MHz (1947). A questo proposito, sto scrivendo un articolo che verrà pubblicato a breve in questa stessa sezione del forum.
Prossimo aggiornamento ai primi di Novembre.
