Solar cycle 24 - summary of last quarter February-March-April 2011
  • Solar cycle 24 - summary of last quarter February-March-April 2011
    (per l'italiano scendere giù)
    As usual, I summarize what happened in the last quarter to solar activity.
    All data necessary for the preparation of the following charts , I have personally done with Excel, have been built from Space Weather Canada. You will therefore notice that I speak only of solar flux at 2800 MHz. I chose to take only this parameter for the study of solar activity because certainly more reliable and objective than the sunspot number. To note, however, that there is a correlation between solar flux and 2800MHz on the number of sunspots.
    I refer, in such plots, unless otherwise indicated, the values "adjusted" of the solar flux, correct (by the Space Weather Canada) to refer to the average Earth-Sun distance (1 astronomical unit), since the actual Earth-Sun distance increases and decreases in summer and winter.
    These are the charts of the last three months.
Nome:   febbraio.jpg
Dimensione: 160.5 KB
Nome:   marzo.jpg
Dimensione: 174.2 KB
Nome:   aprile.jpg
Dimensione: 165.7 KB
    The next one is the graph of the solar flux on 2800MHz from the month of the minimum smoothed solar flux (October 2008) to the present. The red curve is the average monthly value of solar flux, while the blue one is the smoothed value. The data considered are the flux "Adjusted", derived from those physically measured by the Observatory of Penticton (Canada).
Nome:   ciclosolare24.jpg
Dimensione: 145.8 KB
    Some cconsiderations. After the deepest minimum in a century and after a very slow rising up of the solar cycle 24, in february 2011 we had a clear acceleration of the solar activity, exactly one year after the last one in february 2010. This time the solar activity has continued to remain at good levels even in the months following. On March 8, 2011 the solar flux at 2800 MHz reached the new record of 155 sfu and it remained above 100 sfu for the entire month of April.
    As a result, even the blue curve of the smoothed values ​​is now showing a tendency to rise faster.
Nome:   f1003052011.gif
Dimensione: 17.4 KB
    The next update in early August.
    Come di consueto, riassumo quanto si è potuto constatare nell'ultimo trimestre a livello di attività solare.
    Tutti i dati necessari per l'elaborazione dei grafici seguenti, da me personalmente eseguita con Excel, sono stati ricavati da Space Weather Canada. Noterete, quindi, che si parlerà in essi esclusivamente di flusso solare sui 2800 MHz. Ho scelto di adottare solo questo parametro per lo studio dell'attività solare perchè sicuramente più attendibile e obiettivo rispetto al numero di macchie solari. Per il significato e modalità di misura del Solar Flux @2800MHz rinvio all'articoletto n.2 in formato acrobat a suo tempo pubblicato su questo forum. Da tenere presente, in ogni caso, che esiste una correlazione tra flusso solare sui 2800MHz e numero di macchie solari, di cui parlo brevemente sempre nell'articoletto acrobat sopra richiamato. Faccio, inoltre, riferimento, in questi grafici, se non diversamente indicato, ai valori "adjusted" del flusso solare, ossia corretti (sempre dallo Space Weather Canada) per riferirli alla distanza media Terra-Sole (1 Unità Astronomica), considerato che la distanza effettiva Terra-Sole aumenta in estate e diminuisce in inverno. Anche questo particolare aspetto viene brevemente spiegato nell'articoletto acrobat sopra richiamato.
    Questi sono i grafici degli ultimi tre mesi.
Nome:   febbraio.jpg
Nome:   marzo.jpg
Nome:   aprile.jpg
    Riporto ora il grafico relativo all'andamento del flusso solare sui 2800MHz dal mese del minimo del flusso solare smoothed (ottobre 2008) fino all'attualità. La curva rossa è quella del valore medio mensile del flusso solare, mentre quella blu è quella del valore smoothed. Circa la modalità di calcolo del valore smoothed rinvio al solito articoletto n.2 in formato acrobat.
    Dati considerati, quelli del flusso "adjusted", derivati da quelli fisicamente misurati dall'osservatorio di Penticton (Canada).
    Alcune considerazioni. Dopo il più profondo minimo in un secolo e dopo la lenta risalita del ciclo solare 24, a febbraio 2011 si è vista una chiara accelerazione dell'attività solare, esattamente un anno dopo l'ultima forte accelerata verificatasi a febbraio 2010. Stavolta l'attività solare ha continuato a rimanere a buoni livelli anche nei mesi successivi. Il flusso solare sui 2800MHz ha raggiunto il nuovo record di 155 sfu il giorno 8 marzo 2011 e si è mantenuto sopra i 100 sfu per tutto il mese di aprile.
    Come risultato di ciò, anche la curva blu dei valori smoothed ora mostra una tendenza ad una risalita più veloce.
Dimensione: 17.4 KB
    Il prossimo aggiornamento ai primi di agosto.
    Re: Solar cycle 24 - summary of last quarter February-March-April 2011
    Ottima analisi, ed è evidente l'accelerata concomitante con i primi mesi dell'anno, come nel 2010, probabilmente sarà una coincidenza, ma non ci scherzerei troppo, ed anche il comportamento è simile, febbraio e marzo in ascesa, aprile già in leggera (leggerissima) discesa, l'anno scorso la cosa fu ben più notevole e cmq si era su livelli mooolto più bassi, pare quasi un cambio di "velocità", di livello, a febbraio/marzo si "scala" si sale, per poi attestarsi su quella posizione per diversi mesi.
    Ma, queste non sono altro che impressioni, sicuramente è solamente un evento casuale.
    Da dire che, i livelli attuali, sono tali da farci divertire praticamente su tutte le bande, a parte i 10m che spesso restano fuori, ma che hanno cmq regalato cosette interessanti, ed anche se ci fosse un leggero calo o stabilizzazione ai livelli attuali, beh... ci possiamo anche stare, basta pensare a cosa c'era 2 anni fà !!
      Se uno pensava di non dover vedere il flusso solare sui 2800 MHz a valori bassi per un pò, ecco l'amara sorpresa di oggi. Flusso solare (measured) a 84 !
      In fondo il nuovo trend negativo è iniziato ad aprile e sembra persistente. Sempre quando uno decide di partecipare ad un contest (WPX CW della settimana prossima) in banda 10m...
        Non disperare, vedrai che fanno in tempo a risalire, avrai da fare. Io cercherò di fare qualcosa, ma domenica saremo impegnati in 50, per il contest Gargano, e speriamo che anche li, il sole ci dia una mano.
        73 de Mike
        I7CSB Mike
          Sono evidenti un paio di cose, la prima, è la conferma che questo ciclo è nato, e resta, del tutto anomalo rispetto agli ultimi 6 o 7, nessuno lo può cambiare o negare ormai.
          La seconda, è che all'interno del ciclo, sia durante l'ascesa che la discesa, ci sono periodi più "vivi" ed altri meno attivi... da qlc settimana, appunto, l'attivittà è in continuo lento declino, si creano nuove macchie ma restano piccole, non crescono, come la 1218, ha una traccia magnetica decente, è presente da diversi giorni, ma per ora mostra solo un puntino.
          Anche nel behind, per ora, non si vedono grosse cosa, ci vuol pazienza.... soprattutto per i 10m, fino ai 12 le condizioni sono tra buone e molto buone.
            Mamma mia... flusso sotto 85, una sola macchia sul disco solare e niente all'orizzonte... oltre a rischiare lo spotless tra un paio di giorni (e l'infarto per chi fa il Cqww...), maggio rischia di finire ancora sotto aprile che era un pelino sotto marzo, la storia, anche se su livelli diversi, si ripete, mah....
              Altro che, flusso (measured) a 82 ! Svalgaard ha suggerito in effetti un ciclo solare con forti alti e bassi, tanto che alla fine pure la curva smoothed sarà ondulata, a questo punto spero che abbia ragione...
                "speriamo", almeno ci saranno degli alti !
                In effetti non è proprio una bella prospettiva, ma forse meglio di quello che ci si aspettava fino a 5-6 mesi fà, poi gli ultimi mesi avevano riacceso la speranza, ma la realtà è diversa..
                  Secondo me, Art, c'è l'aveva con te che facevi il WPX !
                  Infatti, da sabato sono apparse nuove macchie, alcune ruotate dal behind, altre formandosi dal "niente", ed adesso ci ritroviamo il disco solare tempestato di macchie ed aree attive come non succedeva da un pezzetto... flusso di nuovo oltre 100 e macchie idem, alcune di loro sono grosse e complesse e c'è da aspettarsi anche una notevole crescita.
                  Peccato che, ci siano stati diversi flare che hanno causato condizioni di tempesta geomagnetica sulla Terra, ammortizzando molto quelli che potevano essere gli effetti positivi sulla propagazione, nei prossimi giorni, quando si spera la situazione geomagnetica si tranquillizzerà, le condizioni propagative si faranno sicuramente molto interessanti !
                    Beh, dai, non è andata poi malaccio, in 15m. Scrivo nel merito nell'altra discussione.
                    Sul cluster ho poi visto scorrere roba interessante anche in 10m.
                    Comunque quello che conta è che il Sole si sia scrollato un pò di torpore che sembrava nuovamente averlo preso
                      L'attività negli ultimi giorni è ripresa molto, si sono formate varie nuove macchie e si sono di nuovo raggiunti valori di flusso e macchie degni di nota, in linea a quello che abbiamo visto negli ultimi mesi.
                      Si sono verificati anche diversi flare, che hanno in varie occasioni "perturbato" il campo magnetico terrestre, rovinanda un pò la festa, rispetto a quello che poteva essere in condizioni tranquille.
                      Adesso, pare che si vada incontro ad altri giorni piuttosto quieti, poche zone attive in vista, poco anche nel behind per adesso, flusso e macchie sicuramente in calo, confermando "l'andazzo" di questo ciclo.
                      Da dire che (osservazione personale) oltre alle condizioni ormai prettamente estive (molta insolazione quindi poca roba durante le ore diurne), l'attività radio mi pare molto molto molto asfittica... ascoltare questi tutte le ultime mattine un beacon da VK3 in 10m, che trasmette con poche Watt ed una canna ritta, con la banda completamente deserta è piuttosto deludente !
                      Peccato.
                        e giù, su certi siti web, a riparlare dell'influenza malefica di Giove sull'attività solare
                        Stavolta pare che l'aumento di attività solare degli ultimi giorni di maggio e questi primi giorni di giugno sia stata dovuta all'allineamento Giove-Marte-Venere-Mercurio-Sole che avrebbe attenuato un pò l'influenza di Giove... Mah, non riesco proprio a capire come si possa pensare che un pianeta, seppur il più grande del Sistema Solare, eserciti la sua presunta influenza sul Sole dall'oggi al domani, come quando ne aspettavano il perielio a marzo...
                        Natura non facit saltus...
                        Peccato.
                        Vero. In compenso da diversi giorni ascolto attività per E-sporadico in 10m con l'Europa. E per due giorni di seguito ho sentito VE1TK arrivare bello forte pur se con evanescenza.
                        Ultima modifica di IK7JWY; 06-06-11, 12:25.
                          No so che dirti, le mie conoscenze assolutamente non mi permettono di avere voce in capitolo, dico solo che un mio amico appassionato di astrofisica, trova la cosa impossibile, ma vedo che a supporto di certe teorie ci sono anche "cotanti" cervelli..
                          Si, segnali imponenti in 10m, ed anche qualche apertura con oriente e centro/sud america, secondo (penso) i soliti meccanismi di multihop e tep, qualcosa anche in 50mhz, ma ancora, qui, non si sono avute aperture "massive" con Caraibi o NA.
                            Stasera condizione proprio da minimo solare !
                            In pratica tocca a scendere in 20m, quando invece eravamo abituati a trovare i 15m aperti fino a notte fonda, e spesso anche 10 e 12m !
                            Addrittura qlc anche in 40m, non che la condizione non vi fosse, forse, anche nei giorni passati, ma evidenzia che non trovando molto sulle bande più alte, la gente tende a scendere.... brutto segno.
                            Sarà la stagione estiva, sarà la scarsa presenza, sarà che le macchie latitano di nuovo, sarà il flare di ieri, ma non è un gran bel sentire...
                              E io che oggi mi ero messo in caccia in 6 metri...
