(per l'italiano scendere giù)
As usual, I summarize what happened in the last quarter to solar activity.
All data necessary for the preparation of the following charts , I have personally done with Excel, have been built from Space Weather Canada. You will therefore notice that I speak only of solar flux at 2800 MHz. I chose to take only this parameter for the study of solar activity because certainly more reliable and objective than the sunspot number. To note, however, that there is a correlation between solar flux and 2800MHz on the number of sunspots.
I refer, in such plots, unless otherwise indicated, the values "adjusted" of the solar flux, correct (by the Space Weather Canada) to refer to the average Earth-Sun distance (1 astronomical unit), since the actual Earth-Sun distance increases and decreases in summer and winter.
These are the charts of the last three months.
The next one is the graph of the solar flux on 2800MHz from the month of the minimum smoothed solar flux (October 2008) to the present. The red curve is the average monthly value of solar flux, while the blue one is the smoothed value. The data considered are the flux "Adjusted", derived from those physically measured by the Observatory of Penticton (Canada).
Some cconsiderations. After the deepest minimum in a century and after a very slow rising up of the solar cycle 24, in february 2011 we had a clear acceleration of the solar activity, exactly one year after the last one in february 2010. This time the solar activity has continued to remain at good levels even in the months following. On March 8, 2011 the solar flux at 2800 MHz reached the new record of 155 sfu and it remained above 100 sfu for the entire month of April.
As a result, even the blue curve of the smoothed values is now showing a tendency to rise faster.
The next update in early August.
Come di consueto, riassumo quanto si è potuto constatare nell'ultimo trimestre a livello di attività solare.
Tutti i dati necessari per l'elaborazione dei grafici seguenti, da me personalmente eseguita con Excel, sono stati ricavati da Space Weather Canada. Noterete, quindi, che si parlerà in essi esclusivamente di flusso solare sui 2800 MHz. Ho scelto di adottare solo questo parametro per lo studio dell'attività solare perchè sicuramente più attendibile e obiettivo rispetto al numero di macchie solari. Per il significato e modalità di misura del Solar Flux @2800MHz rinvio all'articoletto n.2 in formato acrobat a suo tempo pubblicato su questo forum. Da tenere presente, in ogni caso, che esiste una correlazione tra flusso solare sui 2800MHz e numero di macchie solari, di cui parlo brevemente sempre nell'articoletto acrobat sopra richiamato. Faccio, inoltre, riferimento, in questi grafici, se non diversamente indicato, ai valori "adjusted" del flusso solare, ossia corretti (sempre dallo Space Weather Canada) per riferirli alla distanza media Terra-Sole (1 Unità Astronomica), considerato che la distanza effettiva Terra-Sole aumenta in estate e diminuisce in inverno. Anche questo particolare aspetto viene brevemente spiegato nell'articoletto acrobat sopra richiamato.
Questi sono i grafici degli ultimi tre mesi.
Riporto ora il grafico relativo all'andamento del flusso solare sui 2800MHz dal mese del minimo del flusso solare smoothed (ottobre 2008) fino all'attualità. La curva rossa è quella del valore medio mensile del flusso solare, mentre quella blu è quella del valore smoothed. Circa la modalità di calcolo del valore smoothed rinvio al solito articoletto n.2 in formato acrobat.
Dati considerati, quelli del flusso "adjusted", derivati da quelli fisicamente misurati dall'osservatorio di Penticton (Canada).
Alcune considerazioni. Dopo il più profondo minimo in un secolo e dopo la lenta risalita del ciclo solare 24, a febbraio 2011 si è vista una chiara accelerazione dell'attività solare, esattamente un anno dopo l'ultima forte accelerata verificatasi a febbraio 2010. Stavolta l'attività solare ha continuato a rimanere a buoni livelli anche nei mesi successivi. Il flusso solare sui 2800MHz ha raggiunto il nuovo record di 155 sfu il giorno 8 marzo 2011 e si è mantenuto sopra i 100 sfu per tutto il mese di aprile.
Come risultato di ciò, anche la curva blu dei valori smoothed ora mostra una tendenza ad una risalita più veloce.
Il prossimo aggiornamento ai primi di agosto.
