(per la lingua italiana scendere giù)
"Mathematics is not an opinion" ..
This article compares the slope of the solar cycle in progress with that of previous solar cycles, from 1947 to 2011 .
The solar flux @ 2800 MHz is taken into account as parameter of solar activity , which has begun to measure precisely since 1947.
The source data on which were drawn up all of the following charts in Excel always come from Space Weather Canada.
We see the first graph of the evolution of the adjusted solar flux @ 2800 MHz (smoothed and monthly mean) since 1947 and identify solar cycles that have taken place in this period.
Adjusted solar flux @2800 MHz from 1947 to january 2011
I then extracted the data for the first 22 months of rising of each solar cycle, for each of them starting from the month in which occurs the minimum adjusted solar flux (smoothed). I then reconstructed for each of solar cycles considered the graph of the evolution of the flux within the first 22 months. In these charts I added a histogram showing for each month in question, the change in value of the flux from the previous month. In practice, this histogram graphically represents the rate of growth of the solar cycle in question.
Below are the charts.
Solar cycle 19 - rising
Solar cycle 20 - rising
Solar cycle 21 - rising
Solar cycle 22
Solar cycle 23 - rising
Solar cycle 24 - rising
I finally gathered the curves of rising in a single chart, to make an immediate visual comparison between the current solar cycle and previous ones, since 1947.
Comparison
Every comment seems superfluous. The current solar cycle, compared to the previous ones since 1947, is a story in itself. The rate of growth is definitely lower. After 22 months of minimum, the value of the solar flux adjusted (smoothed) value is about 80 sfu, whereas all the previous cycles since 1947 had already passed more or less thoroughly the value of 100 sfu.
In the next article, I will publish shortly, will compare the slope of the solar cycle with that of all previous cycles, from 1749 onwards!
On this case, the comparison can only be based on data relating to the Smoothed Sunspot Number (SSN).
Stay tuned.
(if anyone wants to contribute is welcome).
"La matematica non è un'opinione"..
In questo articolo confronto la risalita del ciclo solare in corso con quella dei precedenti cicli solari, dal 1947 ad oggi.
Il parametro di attività solare preso in considerazione è il flusso solare sui 2800 MHz, che si è iniziato a misurare appunto dal 1947.
I dati di partenza sulla base dei quali sono stati elaborati tutti i seguenti grafici con Excel provengono sempre dallo Space Weather Canada.
Vediamo per primo il grafico relativo all'andamento del flusso solare sui 2800 MHz adjusted dal 1947 ad oggi e individuiamo i cicli solari che si sono succeduti in questo lasso di tempo.
Ho , poi, estratto i dati relativi ai primi 22 mesi di risalita di ciascun ciclo solare, partendo per ciascuno di essi dal mese in cui si è verificato il minimo del flusso solare adjusted. Ho quindi ricostruito, per ciascuno dei cicli solari considerati, il grafico relativo all'ndamento del flusso nell'arco dei primi 22 mesi. In tali grafici ho aggiunto un istogramma che riporta, per ciascun mese considerato, la variazione del vlaore del flusso rispetto al mese precedente. In pratica, tale istogramma rappresenta graficamente il rate di crescita del ciclo solare in questione.
Riporto di seguito i grafici suddetti.
Solar cycle 22
Ho, infine, raggruppato le curve di risalita in un unico grafico, per fare un immediato confronto visivo tra il ciclo solare in corso e quelli precedenti, a partire dal 1947.
Comparison
Ogni commento mi sembra superfluo. Il ciclo solare in corso, rispetto a quelli precedenti a partire dal 1947, fa storia a sè. Il rate di crescita è assolutamente più basso. Dopo 22 mesi dal minimo del flusso solare adjusted (smoothed) il valore del flusso (smoothed) risulta di circa 80 sfu, quando invece tutti i precedenti cicli dal 1947 in poi avevano già superato più o meno abbondantemente i 100 sfu.
Nel prossimo articolo, che pubblicherò a breve, confronterò la risalita dell'attuale ciclo solare con quella di tutti i cicli precedenti, dal 1749 in poi !
Il tale caso, il confronto non potrà che farsi partendo dai dati relativi allo Smoothed Sunspot Number (SSN).
Stay tuned.
(se qualcuno vuole contribuire è il benvenuto)
Solar cycle 22
Comparison
Stay tuned.
Solar cycle 22
Comparison
Stay tuned.
