S9-C High Performance Software Defined Receiver
Specification
Architecture DDC/DUC
Freq range 0.25-54Mhz / 54-860Mhz
Sampling rate 120Mhz
Sampling accuracy 16bit
ADC LTC2208-16
54Mhz - 860Mhz MAX2543 Tuner
Freq resolution 1Hz
Mode AM/FM/SSB/DSB/ISB/CW/PSK…
IP3 28dBm; 19dBm(pre-amp on)
Pre-amp 0-10dB
ATT -20dB
SFDR 107dB; 103dB(pre-amp on)
MDS -133dBm @10Mhz, 500Hz BW
-137dBm @10Mhz, 500Hz BW(pre-amp on)
Phase noise -145dBc/Hz@10khz
RSSI 2dB
DDC BW 1200kHz
Sensitivity AM -106dBm 1.12uV@10dB S+N/N 30%MOD@14Mhz
SSB -121dBm 0.20uV@10dB S+N/N 2.1K BW@14Mhz
CW -127dBm 0.10uV@10dB S+N/N 500Hz BW@14Mhz
FM -117dBm 0.32uV@12dB SINAD 3K offset
12kHz BW Deemphasis -6dB
Filter Multi-Band filter module
ANT input protection Gas-discharge tube
Power supply 6V/2A DC
Data output 24bit IQ
Audio output PC
Working temp 0-50c
Size 148.5 x 88.5 x 34.5mm
Antenna 2 x SMA 50Ohm
Program loading power active load
Interface USB 2.0 HS
Venus Information Technology Co., Ltd. Wuxi China
http://www.ba4tb.qth.com
Tel: +86-13861719007
E-mail: sales@ba4tb.qth.com
Specification
ADC LTC2208-16
Freq resolution 1Hz
Pre-amp 0-10dB
ATT -20dB
RSSI 2dB
DDC BW 1200kHz
Audio output PC
Working temp 0-50c
