Intanto ecco subito la foto:
e il video:
http://www.youtube.com/watch?v=vMux00VObHM
queste le caratteristiche , prese dal blog www.cqdx.ru
Features:
Software: ExpertSDR2 (own software)
Direct conversion in RX/TX mode, in HF/VHF bands
Frequency range 0-80MHz, 80-160MHz
Wide band spectrum pan-adapter up to 80MHz
Two independent receivers
Full duplex mode (in the future - software defined).
High dynamic range of receiver: up to 119-120dB in the HF, and up to 114dB in the VHF.
Output power, nominal: 125W(HF), 30W(VHF)
IMD3 DR of transmitter: about 30-40 dB
Reference 10 MHz input
Very small CW delay: 10ms
ADC sample rate: 160MHz
ADC resolution: 16 bit
SFDR receiver: 78-82 dB
DUC sample rate: 360MHz
DUC resolution: 14 bit
High performance 24 bit Audio Codec on board
Connect to PC: LAN/WLAN(Ethernet/WiFi 802.11 g/n)
Power supply: 12-15V 1A(RX)/5A(TX)/ 220V 1.5-2 A.
Weight: 10 Kg
Inputs/outputs:
Two VHF antenna connector(SO239)
Two HF antenna connectors(SO239)
Wide RF input port direct connect to high speed ADC(SMA)(for XVTRX, measurement etc.) (SMA)
Wide RF output port direct connect to DUC(SMA)(for XVTRX, measurement etc.)
RX Out, uses with external BPF, ATT, P.AMP and ADC IN. (SMA)
Reference 10MHz input connector(SMA)
WiFi antenna connectors for 801.11 g/n up to 300Mb/s WAN(SMA)
ALC input port(RCA)
PTT input port(JACK 6.3mm)
CW Key input port(JACK 6.3mm)
External Control port with 9 power switch and RS-485 interface(D-SUB-15)
External Control 2 port for Automotive whip antenna 9310 from Stealth Telecom.
Electret Microphone input(line)(JACK 6.3mm)
Dynamic Microphone input with PTT switch for MH-31(RJ-45)
Headphones output(line)(JACK 6.3mm)
Ethernet connector(RJ-45)
RS-232 connector(DB9)
MIC, LIN, Phone(Jack 3.5mm) - Embedded PC's sound card, for example, for Skype via your transceiver etc.
DC input 12-15V 5A / AC input 220 V 1.5-2A.
HDMI connector for external display.
2xUSB connectors.
"Ground" connector.
Insomma, se non erro, è il primo SDR con le manopole e autosufficiente (non richiede un PC)... L'inizio della svolta ?
Chi sarà a Friedrichshafen lo vedrà dal vivo. Sono gradite impressioni.
e il video:
Features:
Weight: 10 Kg
Inputs/outputs:
ALC input port(RCA)
2xUSB connectors.
"Ground" connector.
