Tratto dalle 'istruzioni per gli operatori' di una spedizione che dovrebbe rallegrarci fra pochissimi giorni. Se avrete la pazienza di leggerle potreste perfino imparare qualcosa...
The DXpedition frequencies
We will stick to the announced frequencies as much as possible. Nevertheless small deviations might
be needed, as e.g. the announced frequency is busy or filled with QRM.
Make sure that once you start calling on a new band/mode, the frequency is clear, and that you have a
reasonable clear RX window.
- See also attached frequency table.
- See also for the band plans.
- Watch out for other DXpeditions and their split windows
- Watch out for annoying rag chewers! They think they have their natal right to be on certain
frequencies every day (no matter if there is already someone before them). And if they feel
uncomfortable with the pile-up you are creating, they like to jam you. So no long wars. If you
feel you have to chance to “fight” against them, change your frequencies
Dividing and spreading your audience
The pileups are going to be huge! Therefore we will have to spread the audience: by using split,
splitting them up by numbers, by continents or by continent zones (e.g. North EU, Near East, …).
You are in control of the pileup! The better you have it under your control the lesser is the chance to
have QRMers on your TX frequency. Of course there are always jammer who are jamming for their
amusement. You can’t avoid these. The only way to minimize their influence is to ignore them and to
be louder then they.
One of the basic rules is that you absolutely stick to the split, be it frequency, zone, number or
continent. There are no exceptions! Once you start accepting exceptions, there is often no stopping of
the undisciplined callers in the pileups. If they feel that you stick to your rules, discipline will be good.
Whatever split you make by working by numbers or continent zones, work until you end the split
sequence. Never stop in the middle of a sequence, e.g. work 1-2-3-4 and stop the pileup at 5. The
crowd is not likely to forgive you for that.
Follow the propagation: Do not run VK/ZL when there is no propagation to the VK/ZL! Use bigger
splits in big peak openings (if needed), but use smaller splits in low propagation.
Make very clear what you doing, in SSB even in a conversational way.
Experiment with the filter bandwith of your transceiver. Find out what’s better for your ears. If you are
just used to very narrow filter settings, try to work some QSOs with wide filters.
(continua)
(continua)
