MORSERUNNER 10' SINGLE CALLS RANKING
(Morserunner is a software by VE3NEA)
Impostate il software in questo modo:(Morserunner is a software by VE3NEA)
(in italiano più giù)
Set the software in this way:
CW Speed --> as you like
NO QRN
NO QRN
NO QSB
NO FLUTTER
NO LIDS
for --> 10 min.
Single Calls
To enter the ranking is necessary to produce the audio file and the log of own performance .
Before starting the session with Morserunner, remember to activate the audio recording ( File menu -> Enabled Audio Recording ) . After the session , if you have passed your previous record , store the audio file " Morserunner.wav " (found in the program directory ) . This audio file generated by the software must then be converted by the participant in mp3 format ( frequency: 11025 Hz channels: Mono , Bitrate : 16kbps ), for example using the freeware software http://www.koyotesoft.com/indexEn.html, and renamed as "yourcallsign.mp3", the size of the mp3 files should be somewhere about 1.2 Mbytes . We do not accept audio file size larger than 1256 KB .
At the end of the 10 minute session , in addition, be careful not to close the program before doing the copy&paste the log and taking note of the score , because it is data that is deleted at the end of the program and there is no trace of what you have done .
The log must be in text format with the extension .doc or .txt . Just copy&paste ( CTRL C and CTRL V) into wordpad and save as "yourcallsign.txt" or "yourcallsign.doc" if you are using Microsoft Word.
Who wants to listen to the audio or view the log of any of the participants will have to click on the appropriate links visible in the rankings.
Try to put the results of your last session of 10 minutes with Morserunner . The system is completely automatic , obviously it does not verify that the number of multipliers and QSO is actually the one resulting from the audio files and the log. The staff reserves the right, however, to conduct inspections . It ' just a game, you do not win anything!
If you already are in the rankings and you send the data of a new session, the details of your previous session are still visible in the rankings as long as the staff will not eliminate them.
The ranking is initially displayed in chronological order of data input . To display in descending order of the number of QSOs , just click twice on the button QSO. So for any other ordering criteria.
NO QRN
NO QRN
NO QSB
NO FLUTTER
NO LIDS
for --> 10 min.
Single Calls
CW Speed --> come vi piace
NO QRN
NO QRN
NO QSB
NO FLUTTER
NO LIDS
for --> 10 min.
Single Calls
Per entrare nella classifica dei partecipanti alle sessioni 10' in modalità single calls è necessario produrre il file audio e il log della propria prestazione.
Prima di iniziare la sessione, quindi, ricordatevi di attivare la registrazione audio (menù File-->Audio Recording Enabled). Dopo la sessione, se avete superato il vostro record precedente, archiviate il file audio "Morserunner.wav" (lo trovate nella directory del programma). Questo file audio generato dal software dovrà poi essere convertito a cura del partecipante in formato mp3 (frequency: 11025 Hz, channels: mono, bitrate: 16kbps) , ad esempio utilizzando il software freeware http://www.koyotesoft.com/indexEn.html, e rinominato in vostrocallsign.mp3 La dimensione del file mp3 dovrebbe aggirarsi sugli 1,2 Mbytes. Non sono accettate dimensioni del file audio maggiori di 1256 KB.
Alla fine della sessione di 10 minuti, inoltre, attenzione a non chiudere il programma prima di aver fatto il copia&incolla del log e aver preso nota dello score, perchè sono dati che vengono cancellati alla chiusura del programma e non resta traccia di quanto avete fatto.
Il log dovrà essere in formato testo con estensione .doc o .txt . Basta fare copia&incolla (CTRL C e CTRL V) in wordpad e salvare come vostrocallsign.txt o vostrocallsign.doc se si fa uso di Word.
Chi vuole ascoltare l'audio o visualizzare il log di qualcuno dei partecipanti, dovrà fare click sugli appositi links visibili nella classifica.
Provate a inserire i risultati della vostra ultima sessione da 10 minuti con il Morserunner. Il sistema, del tutto automatico, ovviamente non verifica che il numero di QSO e di moltiplicatori sia effettivamente quello risultante dai files audio e dal log, che vanno comunque allegati. Lo staff si riserva, tuttavia, di procedere a verifiche. E' solo un gioco, non si vince nulla !
Se siete già in classifica e inviate i dati di una nuova sessione, i dati della vostra precedente sessione risulteranno ancora visibili in classifica finchè lo staff non provvederà ad eliminarli.
La classifica viene inizialmente visualizzata per ordine cronologico di inserimento dei dati. Per visualizzarla in ordine decrescente di numero di QSO, basta fare click due volte sul pulsante QSO. Così per eventuali altri criteri con cui ordinare la classifica.
